Why can’t I see all my Fibaro devices in Alexa app?
I have been using HC2 now with the Fibaro skills ever since they were available. My problem though is that the Alexa app cannot discover any of my Fibaro motion or door sensors.
it sees my Aeotec Wall plugs, Fibaro Dimmer 2, Hue Bulbs and Hue motion sensors. It  cannot see any Fibaro sensors in the app. I have disabled both Fibaro skills, deleted Alexa app and setup again (Alexa remembered my previous config)
no matter what I do or have done for the start I can’t get Alexa to see these devices.
Alexa app up to date and Fibaro HC2 running 4.580
I have read topics here about clearing all the devices and setting up from fresh but I don’t see any forget devices option or delete all.
any suggestions?
thanks
5 answers to this question
go to amazon alexa ...
Select:
1. smart home
2. devices
3. scroll down
4. forget all
5. discover (again)
but first go to your home/fibaro.com and check is on your HC integartion got status active
Please remeber that you must be a owner HC
    @A.Socha Thank you for your guidance.
    I ran through both as you listed but Alexa app still doesn't see any Fibaro sensors.
    I don't know if this would affect the issue or if others can tell me if theirs is the same but when I check my skills in the drop down menu in the Alexa app I can see both Fibaro skills as active and linked but if I go to devices>'Your smart home skills'I only see one of Fibaro skills listed (FIBARO Smart Home Skill)
    I also do not see all my Fibaro scenes.
    Where you saw that sensor are visible in Alexa?
    @A.Socha I checked the details here I the forum and saw this...
     you can control sensors, scenes and more
    But then when you look down the list it says you cannot discover these security type devices
    It all seems very contradictory.
    Edited by MrConstruction
