Problem with Normaly Closed setting
Hi
I have setup OUT2 as normaly closed (Parameter 155  = 1)  and OUT1 as Normaly opened. So my expectation is that normally current flows through OUT2 and it stops only when I press button associated with OUT2. However it works as it would be configured as Normaly Open and current flows only when I press button associated with OUT2. Acutally I can't see difference in behaviour of OUT1 and OUT2 althoug configuration is different. My controler is HC3. Any idea what is wrong?
[21:14:01] ID 220: Received association report from group 1
[21:14:01] ID 220: Received association report from group 2
[21:14:01] ID 220: Received association report from group 3
[21:14:04] ID 220: Received association report from group 1
[21:14:04] ID 220: Received association report from group 2
[21:14:04] ID 220: Received association report from group 3
[21:14:06] ID 220: Received parameter 24 report, value = 0
[21:14:06] ID 220: Received parameter 25 report, value = 0
[21:14:06] ID 220: Received parameter 40 report, value = 0
[21:14:06] ID 220: Received parameter 41 report, value = 0
[21:14:06] ID 220: Received parameter 47 report, value = 255
[21:14:06] ID 220: Received parameter 49 report, value = 0
[21:14:06] ID 220: Received parameter 52 report, value = 255
[21:14:06] ID 220: Received parameter 54 report, value = 0
[21:14:07] ID 220: Received parameter 63 report, value = 5
[21:14:07] ID 220: Received parameter 64 report, value = 0
[21:14:07] ID 220: Received parameter 65 report, value = 5
[21:14:07] ID 220: Received parameter 66 report, value = 0
[21:14:07] ID 220: Received parameter 67 report, value = 5
[21:14:07] ID 220: Received parameter 68 report, value = 0
[21:14:07] ID 220: Received parameter 150 report, value = 10
[21:14:07] ID 220: Received parameter 151 report, value = 10
[21:14:07] ID 220: Received parameter 152 report, value = 0
[21:14:08] ID 220: Received parameter 153 report, value = 0
[21:14:08] ID 220: Received parameter 154 report, value = 0
[21:14:08] ID 220: Received parameter 155 report, value = 1
[21:14:08] ID 220: Received parameter 156 report, value = 1
[21:14:08] ID 220: Received parameter 157 report, value = 1
