Just installed 7 Qubino Flush Shutters but having problem with shutter positioning, keeps jumping limit.  How and where is this manually accomplished? Thanks!
@Badger5
Shutter positioning calibration
(par. 71 set to 0)
There are two options to calibrate the device:
• Calibration through the main gateway (hub) UI
1) Include the device into the Z-Wave network according to the instructions for inclusion.
2) Set the parameter 78 (Forced Flush Shutter calibration) value to 1.
3) Flush Shutter performs the calibration process, completing full cycle - up, down and up again.
4) Set the parameter 78 (Forced Flush Shutter calibration) value to 0.
    akatar,
    Thanks for the reply, however page 41 does not specify under which tab calibrating can be accomplished for these shutters.
    i am sorry, i don't own any fibaro controller. so what do you mean with: under which tab?
