HC3 Call button from scene
How do i call a button from a scene in HC3
fibaro.call(48,"turnOn") only works in "main" window, but not if i make it inside a button window
can i call it by ID or function?
Old in HC2: fibaro:call(xxxxx, 'pressButton', '1')
Edited by Sagittarius
4 answers to this question
fibaro.call(48,"turnOn") only works in "main" window, but in if i make it inside a button
See this thread:
    I try'd but i cant get it to work still
    ________
    From scene:
    fibaro.call(48,"test","hejhejhej")
    In QA main lua window:
    function QuickApp:test(arg1)
        self:debug("TEST: ",arg1)
    output: [DEBUG] 14.03.2020 15:26:13: TEST: hejhejhej
    So that is working..
    If i make an button called ON, an put in the Lua in the button window
    function QuickApp:on()
        self:debug("binary switch turned on"-- debugging method will work
    and from a scene call:
    fibaro.call(48,"on")
    nothing happens
    ________
    From scene:
    nothing happens
    I'm definately not a coder, so I could be very wrong, but you have added an argument for the function, but are not providing any argument in the scene call? Could it be a missing argument? For me this works (as in the link I sent):
    QuickApp main code (send an IR code):
     function QuickApp:btn_Power()
     self:send("sendir,1:3,1,37993,1,1,171,171,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,21,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,64,22,21,22,21,22,21,22,37000x0D0x0A"true)
    QuickApp button:
    In the button for the QA (named btn_Power), I put:
    self:btn_Power()
    Scene calling QuickApp button:
    In the calling scene, I put in this code:
    Conditions/Trigger:
      conditions = {},
      operator = "all"
    LUA main code:
    fibaro.call(213"btn_Power")
    Edited by robw
    After new update all works again, thank you :)
