HCL - scene activation od Double Switch 2 double click
Hi, I am using Double Switch 2 with Home Center Lite (HCL). I am trying to activate scene when S1 is double clicked, but I didn't find any clues how to do it.
Anybody can help?
8 answers to this question
@redzioch I got similar problem and answer in polish you can find here
I want to do the same thing..
I just started to use this system, and i'm finding it dissicult.
I used google transate on the text, so that was fine. But i can't get my block scene to resemble yours.
-First you choose the room
-Then "wall lamp switch"
"Central Scene ID". whats that? I can only choose "scene activation event" and choosing that doesnt give me the options you have.
@Kouzco you need to activate sending scenes trigger to HC, it's Parameter 28 for S1 and Parameter 29 for S2
Sorry for the slow feedback, not allways home during weekdays and can't work on the system...
Parameters are a littlebit different on your system...
Here is what mine looks like
@Kouzco what type of device are you trying to configure? maybe those params are under different numbers?
Its a dimmer2..
I've looked up and down the list.. I've been told I'm blind.. but can't find it..
@Kouzco my response was regarding Double Switch 2. Let me see what I have in Dimmer 2, but I didn't have opportunity to play with it yet.
I don't mean to nag, but did you find the time to check?
