Hello! I am running a z-wave+ network of several fibaro devices controlled by a raspberry pi. one amongst the devices is the fibaro eye that I use mostly as a temperature sensor. I have been been trying to programme rules such as "if temperature (as reported by the fibaro eye) is lower than 20C, then turn on a fibaro single switch activating an electric heater. I haven't succeeded yet. Thanks for any advice.
If i remember correctly i had to enable the temperature function for pir by going into, devices-visibility - show hidden  - tool config/ and mark off hidden in system.
Afterwards simply use in scene, block scene etc.
Sorry , forgot you do not use home center. What program are you using for controller ?
Edited by MARCUSP.I.L
    Thanks for the answer. I am using Z-wave 3.0, an open source controller running on razberry, a hardware card fitted on a raspberry pi (see
    . I have by now five or six actors and sensors (mostly Fibaro technology) integrated in a z-wave mesh network, and simple automation like schedules works fine. However when I push it further and try to include rules, even a simple "if-then" routine fails to do its job. I have been in contact with the designer of the Razberry Z-wave software, but the problem seems to be on the side of the Fibaro eye temperature sensor that seems unable to trigger Fibaro actors such as a single switch.
    Thanks again
