Way to disable and enable debug in scenes and VD's
I want to create a debug variable with the values ON and OFF. When the value is ON then I want debug to be activated in all scenes and VD's and the opposite when the value is OFF.
But how can I incorporate this in all scenes?
Thank you in advance?
Kevin
Ex. by get and check value of variable or local at beginning of code scene, main loop, vd code in small function and use it on replace fibaro:debug
    @drboss
    Thank you for your quick answer.
    If I understand it correctly, I need to add this to every scene/vd.
    I also need to replace fibaro:debug(“xxx”) by mydebug (‘red’, ‘xxx’)
    I'm curious, what is possible reason to do so?
    Another way... you can create a scene that always deletes debug message from all scenes and VDs or keeps the messages.
    please refer to
    Edited by cag014
    Thnx @cag014
    The reason that I want this is, is the same reason of the scene you mentioned?. I don't want that the debug is full of lines and causes issues. But your scene is also perfect to do so.
    I only have 1 question, when I download version 1.2 the text file shows a lot of stuff in the header. Also a lot of \par in the code. I think there is an error here (see attached screenshot)
    Sorry old version...
    Please open with wordPad and copy to scene.
    Let me know if it is OK
    Edited by cag014
    I download ClearDebugMsg_v1.2.txt
    Open it with Texteditor on my Mac (Texteditor is the Wordpad on Mac) but still the same ?
    This is version with removed wrong coded for past in HC2 special characters:
    Probably because of .txt extension Mac opens as notepad...
    Please try below... pure text file
    Thanks too the both of you
    Edited by kevin
    @cag014
    Is there a way to exclude a scene/VD from the scene? I get an error on a VD button but that button works without issues.
    I will see what can I do..
    But why not to fix the error?
    You don't necessarily have to adjust the scene for me, it was more a question of whether this functionality was already present in the scene.
    I can't get the error resolved, I'm not a LUA expert (yet?), but I'm going to contact the person who wrote the scene.  In addition, I have recently been experimenting with LUA (scenes and VDs), so if you ever release an update of the scene then this feature seems like a good addition to me.
    @kevin
    Per your request, have released new version with option to define devices/scenes/VD to ignore error.
    Wait for fibaro approval. I believe it will be available soon.
    Wow thanks for the quick update of the scene.
    Looks like this will take a lot to approve the code...
    Please download below and let me know if it works
     added ignoreErr global variable to define devices/scenes on which error will be ignored and not reported.
    To define virtual device button, use <deviceID>b<button number>.
    See example above "535b1". Ignore error in virtual device 535 button number 1.
    I tried this code but i get the following error
    [DEBUG] 22:32:52: 2020-04-01 22:32:52.485236 [ fatal] Unknown exception: /opt/fibaro/scenes/639.lua:147: unexpected symbol near '}'
    btw... I changed the ignoreErr devices to match the devices not to monitor
    Oops... my bad
    Try below
    You removed the last "}"?
    I removed and it works
    Yes... typo sorry
