My First Scene, after sunset - motiondetector (HC3, Block) not working
I'm setting up my first scene, it's simple so far, just trying to get the basics to work, but no luck.
All i want so far is the light to light up if i walk into the bathroom after sunset. But i can't ge tit right.
If i remove the sunrise/sunset trigger the light goes on. So i know it's not an issue with the detector.
what am I doing wrong here?
The only thing I can think of is that the scene will now only activate if its 1 minute after sunset, 1 minute before sunerise and i trigger the motion at the same time. which i ofc impossible.
If this is the case, how to I get a scene to trigger while dark outside?
totalnoob
Edited by Kouzco
    Hey guys!
    Thanks for the feedback. Like i've said before, I'm sorry for the slow response. But a mixture of work and family makes  the time I have to look into this very little and very spread apart.
    I've now tried implementing and heres is what I have done.
    Declaration side has stayed untouched, but for simplicity I will quote it here.
    Quote
      conditions = { {
          id = 138,
          isTrigger = false,
          operator = "<=",
          property = "value",
          type = "device",
          value = 0
          id = 136,
          isTrigger = true,
          operator = "==",
          property = "value",
          type = "device",
          value = true
          conditions = { {
              isTrigger = false,
              operator = "match>=",
              property = "cron",
              type = "date",
              value = { "00""20""*""*""*""*" }
              isTrigger = false,
              operator = "match<",
              property = "cron",
              type = "date",
              value = { "00""08""*""*""*""*" }
          operator = "any"
      operator = "all"
    On the Ation side I added "local light = 133" on the third line. I assume this is for the LUA to include it in the code (?). Then I added " fibaro.getValue(133,"value") " on the line after " safeTime,"to maxTime ",maxTime) "
    I'm not sure whats gone wrong, because now the scene won't run at all when someone enters the room. So that naturally results in me not beeing able to check if the function we wanted added works.
    See below.
    Quote
    local light = 134
    local motion1 = 136
    local light = 133
    local maxTime = 1*60  -- max time the
    local sleepTime = 5   -- time in seconds
    fibaro.debug("","Turning on")
    fibaro.call(light,"turnOn")
    local safeTime = 0
    while safeTime < maxTime do
      fibaro.sleep(sleepTime*1000)
      safeTime=safeTime+sleepTime
          -- count up safeTime
      fibaro.debug("","Counting up safeTime ",
      fibaro.getValue(133,”value”)
    then -- motion breached
         safeTime=0
          -- reset safeTime
         fibaro.debug("","Reset")
    fibaro.debug("","Turning off")
    fibaro.call(light,"turnOff"
    Thanks again!
         safeTime=0
          -- reset safeTime
    I think there has to be an if in front of the fibaro.getValue
    local light = 134
    local motion1 = 136
    local light = 133
    And the light value 134 will be overwritten by 133. That won’t do any good.
    I don’t know what the ID’s are for your setup
    light = 134 (the light to turn on) ?
    motion sensor = 136 ?
    other light = 133 ?
    and what is ID 138 in the declaration ?
    this is what the code should be (but maybe not the correct ID’s)
    Edited by SmartHomeEddy
    other light = 133 ?
    134 = the light the motion sensor turns on
    136 = motion sensor
    133 = is the other light. If this light is turned on, then the scene should cancel. As in not turn 134 off again.
    138 = is the light sensor (lux)
    Ok, I've copied what you quoted in replacing the old.
    When the scene is run the light still does not light.
     under is the current action
    Quote
    local light = 134 -- ID of light to turn on
    local motion1 = 136 -- ID of motion sensor
    local otherlightID = 133 -- ID of other light when turned on, "light" won't turn off
    local maxTime = 1*60  -- max time the sensor should be safe before turning off
    local sleepTime = 5   -- time in seconds between each check of the sensor
    local safeTime = 0
      safeTime=safeTime+sleepTime -- count up safeTime
      fibaro.debug("","Counting up safeTime ",safeTime,"to maxTime ",maxTime)
      if fibaro.getValue(motion1,”value”) or fibaro.getValue(otherlightID,”value”) != 0 then -- motion breached or other light is on
         safeTime=0 -- reset safeTime
    fibaro.call(light,"turnOff")
    But did you meet all conditions according to the declarations?
    It must be dark (lux <= 0)
    there must be movement
    it must be between 20:00 and 8:00 hour
    I did yes.
    And I've also tried running the scene manually. It does not light even then. So something is canceling it out?
    Do you see anything in the debugging screen?
    [SCENE47]: (load):16: unexpected symbol near '<\226>'
    I'm assuming this is the culprit ?
    Please replace this line
    With
    Done!
    Still same error
    Quote
    [16.08.2020] [01:08:33] [ERROR] [SCENE47]: (load):16: unexpected symbol near '<\226>'
    Actions now:
    Quote
    local safeTime = 0
      if fibaro.getValue(motion1,”value”) or tonumber(fibaro.getValue(otherlightID,”value”)) > 0 then -- motion breached or other light is on
    Djees... This LUA stuff is hard. :)
    Thanks for the hep so far :)
    If have tested this code om my setup with some different ID's and this works now. I have added a debug tag for more easy debugging and an extra debug message to see wat the script does (motion or other light). Copy - Paste and lets see...
    I'm new to this LUA scripting also and could use your script to make a start for dimming kitchen lights; when nobody is in the kitchen, lights will be go back to 30%
    I used your script for this:
      conditions = { {
          id = 43,
          isTrigger = true,
          operator = "==",
          property = "state",
          type = "device",
          value = true
          id = 27,
          isTrigger = true,
          operator = "==",
          property = "value",
          type = "device",
          value = true
      operator = "all"
    local light = 43
    local motion1 = 27
    fibaro.debug("","Turning on to 90%")
    fibaro.call(light,"setValue","90")
    local safeTime = 0
      if fibaro.getValue(motion1,"value")
         safeTime=0
          -- reset safeTime
    fibaro.debug("","Dimming to 30%")
    fibaro.call(light,"setValue","30")
    Thnx anyway i could use this.
    I changed some little things:
    - in the condition I changed 'value' to 'state' (because the lights already switched on).
    - in the action part I put a 'setValue' to 90%
    - and did some debug changes.
    For so far it works well
    Still I have a some questions:
    Here are some logs:
    [19.08.2020] [00:40:41] [DEBUG] []: Counting up safeTime 10 to maxTime 60
    [19.08.2020] [00:40:46] [ERROR] [SCENE25]:
    [19.08.2020] [00:40:46] [DEBUG] []: Turning on to 90%
    [19.08.2020] [00:40:51] [DEBUG] []: Counting up safeTime 5 to maxTime 60
    Why there is an 'error in this scene?
    One other question:
    dimming to 30% is very nice and slow, that's ok, i changed some parameter in the Dimmer 2.
    But dimming back to 90%, could be faster, as my Motion trigger some action, ít would be nice the person in the kitchen gets some light quicker. Is there a possibility to script this in the LUA?
    Hi @Sijbrand,
    I copy paste the scene, only changed the id’s, turned on the light and let motion do its work. No errors. Are you sure scene25 is this scene?
    Goodmorning,
    yes, it's the correct scene, all other scenes i switched off:
    Strange, nothing here
    maybe this setting?
    /monthly_2020_08/78AF9790-1CCE-4759-BAEF-7EC914B3766F.jpeg.d7997ef095867bc113dc504630945227.jpeg" />
    Yeah, strange... i will check again, during the day...
    But do you have some answers on my second question? I would like 2 different speed's: 1 for dimming to 30% and dimming back to 90%
    Maybe the “allow to restart” setting?
    I don’t use that function, it is just on its default setting. You could however alter the parameter setting from Lua, but I don’t know how reliable that is, doing it often maybe with short intervals.
    I use this in my humidity scene:
    But on my search then, I got a warning to use it carefully.
     Did you filter also on 'Error'?
    No filter, all messages
    Did you check the allow restart setting?
    aha.... i change it to 'Nee', and no error this time... that's the solution !
    /monthly_2020_08/image.png.b6a630be03f4efb3b5d8e451fb4d054a.png" />
    Thnx...
    Edited by Sijbrand
    I've been testing it over 2 days now and it seems to be working. Will rund a few more test and get beck to you.
    But so far so good. Thanks a lot!! ??
