bker 0
Hi All,
I am trying to get a understanding of creating VD's for control of my TV's and projector. I was able to download a VD from the Fibaro Market Place for my Panasonic TV which works. I am currently running v4.580
I have spent the last 2 days trying all sorts of different LUA codes to try and control my JVC projector which I can control via telnet from my laptop though I am stuck trying to do this from a VD. Below is what I have tried and the projector requires the following TCP/IP command PJREQ first then it leaves the socket open for 5 secs so you can send the next command. I am only looking to be able to turn it on & off. In the example below is the HEX string to turn the projector ON............apologies this is all new to me so any help would be very much appreciated
I have already assigned the correct IP address and Port in the advanced section of the VD..........I just can't workout how to sent the actual command strings
local device = fibaro:getSelfId();
local ipaddress = fibaro:getValue(device, "IPAddress");
local port = fibaro:getValue(device, "TCPPort");
FIBARO = Net.FHttp(ipaddress, port)
tcpSocket:write(string.char(PJREQ))
tcpSocket:setReadTimeout(5000);
tcpSocket:write(string.char(PJREQ));
tcpSocket:write(string.char(21 89 01 50 57 31 0A));
tcpSocket = Net.FTcpSocket(ip, port);
6 answers to this question
