FBerges 52
Hello everyone
I would like to query with the HC3 2 doorbell button (that's not a problem) and then let a number or number range ring on the Fritzbox.
Even with the Fritzbox and the ringtones is no problem, only the connection from the HC3 to the Fritzbos gives me a headache.
There is a circuit that allows a VOIP number to be called from a keystroke (bell button) via DECT but I have a subsystem again and that is exactly what I did not want.
Maybe there is a solution from you.
I already gave up the ringing and the Alexa if that were the nicer solution. Since that also fails with the connection of the HC3 -> Alexa systems.
Greetings from the Sauerland
F.B.
