Scene Controlled Via Contact Switch
Guest puma
I am still trying to get the hang of LUA it's not going so great but I am trying to write a basic scene to turn on my garage lights on when either one of my garage doors are opened. However I can't get it to work correctly at this stage it will only work if I manually run the scene once the door is open it doesn't seem to realise that the door has opened.
It would also be nice to some how put a timer on it to say turn off after 5 mins.
This is what I have come up with.
%% properties
237 Value
%% events
%% globals
local myVariable
myVariable = fibaro:getValue(237, "state")
if (myVariable == 'Open') then
  fibaro:call(542, "turnOn")
I did this on my HC3 look!
But I also have sensors for the garage open and close at my gate.
And this is translate in LUA
greetings
F.B.
Edited by FBerges
Guest puma
    Thanks for your help but I don't have a HC3 I am running a HC2.
    Guest puma
    So I have done a little work and managed to come up with this however it still isn't right.
    %% properties
    237 state
    %% events
    %% globals
    if (tonumber(fibaro:countScenes()) > 1)
    then
        fibaro:debug("Script already running.");
        fibaro:abort();
    if (fibaro:getValue(237, "state")== "Open")
    then
        fibaro:call(542, "turnOn");
        fibaro:sleep(300000)
        fibaro:call(542, "turnOff")
    if (fibaro:getValue(237, "state")== "Close")
    then
        fibaro:call(542, "turOff");
    It does work when I open the door although for some reason it is quite delayed the door will be open for a good 10 seconds before it will turn the lights on.
    The timer does work for 5 mins however if I close the door it doesn't turn the lights off it will only go out with the timer.
    What have I done incorrectly?
