Turn on Light from string VD
I have a VD Im using to populate variables for status. One of them works as below.
PUT /api/globalVariables/entrySensor HTTP/1.1
Host: 127.0.0.1
Authorization: Basic c2VhbkBzbWFydGVyZWxlYkhglhgjhbjhbkjhjhbkjhbkjbvkjhv. (not actual code)
{"name":"entrySensor","value":"Override"}
I want to use the same methodology to add a simple on and off button to this VD to control a dimmer or relay.
How would I go about this? Ive read through the HC2/docs , fibaro developers and this forum but just cant get it to work .
I go ok with LUA but this stuff kills me.
Thanks.
Guest Turmoil
Hi, I've just documented my experience with virtual devices here:
Its not everything but perhaps it will answer your questions.
