StefanD 1
my roller motors require a minimum pause between switching direction.
Example: If the motor is currently winding upwards, and then stopped, it is necessary to wait minimum 500ms before downward winding is started. Reason for this requirement are capacitances within the motor that need to uncharge first. Otherwise, the motor could break.
Question: As Fibaro FGR223 has no programming switch for that, does it implement some fixed minimum delay? If yes, how long is it?
Stefan D.
