StefanD 1
thought I build some automatic roller by using a Rademacher Jarolift and attaching a FGR223.
As the motor has no end switch, I need to set the coding switches 156 and 157 (Time of up movement/Time of down movement). This works ok in that that the motor stops after the specified time.
However, the FGR223 seems to not monitor the positioning of the roller. If I send it up, and stop it at middle position, then the next up will activate the motor again for the full time specified in value 156.
I would have expected that there is some logic that counts the seconds of already passed time of up movement such that those time limits resemble somewhat two end switches. Am I wrong with my expectation?
Thanks for answer,
Stefan D.
