Set parameters in LUA
I have a NEO coolcam siren here and I want to use it for alarm messages.
Say different tones for different messages.
So far so good.
If I carry out the parameters via the device setting, the settings in the siren also change.
However, if I do it as stated above about a LUA scene, nothing changes.
The stupid thing is I don't get an error message the part runs through without changing anything and the sound doesn't matter what I do.
The sleep in between are only to try if the siren may need a break between the parameter setting.
They have to get out or get smaller.
Has anyone ever tried this and can tell me where the error is?
Edit here is the manual.
HC3, Latest firmwhare
I wrote the following :
function sirene_tuerklingel(DeviceID, SirenenTime)
    fibaro.call(DeviceID, "setParameter", 1, 1, 3) -- Alarm Sound Volumen 1-3
                                                      -- 1=Low
                                                      -- 2=Middle
                                                      -- 3=High
    fibaro.call(DeviceID, "setParameter", 2, 1, 1) -- Alarm Sound Duration Time 0-3
                                                      -- 0=Sirene is not on
                                                      -- 1=30Sek.
                                                      -- 2=1min
                                                      -- 3=5min
    fibaro.call(DeviceID, "setParameter", 3, 1, 3) -- Door Bell Sound Duration Time 1-127
                                                      -- 1-127 Time
    fibaro.call(DeviceID, "setParameter", 4, 1, 3) -- Door Bell Sound Volumen 1-3
                                                      -- 1=Low
                                                      -- 2=Middle
                                                      -- 3=High
    fibaro.call(DeviceID, "setParameter", 5, 1, 10) -- Alarm Sound Index 1-10
                                                      -- There ar 10 different Sound
    fibaro.call(DeviceID, "setParameter", 6, 1, 9) -- Door Bellsound Index 1-10
    fibaro.call(DeviceID, "setParameter", 7, 1, 2) -- Default Siren On Mode 1-2
                                                      -- 1=Alarm Sound Mode
                                                      -- 2=Door Bell Sound Mode
    fibaro.call(DeviceID, "setParameter", 8, 1, 1) -- Alarm LED Enable 0-1
                                                      -- 0=LED will be disable
                                                      -- 1=LED will de enable
    fibaro.call(DeviceID, "setParameter", 9, 1, 1) -- Boor Bell LED Enable 0-1
    fibaro.call(DeviceID,"turnOn")
    fibaro.sleep(SirenenTime)
    fibaro.call(DeviceID,"turnOff")
function sirene_einbruch(DeviceID, SirenenTime)
                                                      -- 1=Low
                                                      -- 2=Middle
                                                      -- 3=High
    fibaro.sleep(1000)
                                                      -- 1=30Sek.
                                                      -- 2=1min
                                                      -- 3=5min
    fibaro.sleep(1000)
                                                      -- 1-127 Time
    fibaro.sleep(1000)
                                                      -- 1=Low
                                                      -- 2=Middle
                                                      -- 3=High
    fibaro.sleep(1000)
    fibaro.call(DeviceID, "setParameter", 5, 1, 3) -- Alarm Sound Index 1-10
    fibaro.sleep(1000)
    fibaro.call(DeviceID, "setParameter", 6, 1, 3) -- Door Bellsound Index 1-10
    fibaro.sleep(1000)
    fibaro.call(DeviceID, "setParameter", 7, 1, 1) -- Default Siren On Mode 1-2
    fibaro.sleep(1000)
    fibaro.sleep(1000)
    fibaro.sleep(1000)
--MAIN
--sirene_tuerklingel(438,2000)
sirene_einbruch(438,2000)
greeting F.B.
6 answers to this question
    Hi
    So I have the solution to the problem.
    That is a simple documentation error by Fibaro.
    Look here!
    So I tried a Fibaro Smart Implant FGBS-222.
    (I had a network here with a power supply relay etc. for my doorbell campaign)
    After manual switching (parameter 24 from 0 to 1), inputs E1 / E2 are swapped and function as described in the manual.
    Now with the LUA
    fibaro.call (440, "setParameter", 24, 1, 1) and fibaro.call (440, "setParameter", 24, 1, 0)
    Result NIX but something of NIX !!!
    On the one hand it calms me (nothing wrong), on the other hand sh… my idea doesn't work!
    I hope this will be fixed quickly if it doesn't work because of some desperation.
    Greetings and a nice Weekend
    FB
    Edited by FBerges
    hi @FBerges
    very interested into your experience having also a neo coolcam siren + Aeon Labs one for which i would like also to have a QA to settle parameter before ringing it (sometime medium volume with music for door bell, sometime full volume with sirens sound for alarm).
    I was having a VD in HC2 doing it but no way adapting it for HC3... can't manage doing it :(
    did you find any solution for the issue since?
    have you managed to create a QA for?
    thanks for your return of experience and have a good week end,
    br
    mathias
    @mateo
    Hi
    No I have not yet found any other solution for this.
    The command "setParameter" does not work and is, according to my information, an error in Firmwhare 5.030.
    What I know is that a Betta from Fibaro is out and I hope that the bug is fixed.
    Waiting for the release since I am not a betta tester.
    Hope dies last.
    I have 3 useless sirens waiting to be used.
    Greetings to the neighboring country
    Frank
    dont use fibaro.sleep(1000) (you send on 1s action to hold bettter use
    @mateo
    hello mateo
    I now have my NEO coolcam siren running well.
    My problems are actually an error in the Fibaro documentation.
    The command to change the register is:
    fibaro.call (siren ID, "setConfiguration", 1, 1, 1)
    I have solved the problem.
    Then I set all the parameters as I needed it for each purpose and it worked.
    Now look like this:
    -- Signal Nr.2 = Einbruch KG
    function Sirene_Einbruch()
        --Wenn der Letzte Ton der abgegeben wurde,
        -- nicht Einbruch ist dann muss Initialisiert werden
        if sirenen_alarm_ton ~= 2 then
            fibaro.call(sirene3, "setConfiguration"111-- Alarm Sound Volumen 1-3
        -- 1=Low
        -- 2=Middle
        -- 3=High
            fibaro.call(sirene3, "setConfiguration"211-- Alarm Sound Duration Time 0-3
        -- 1=30Sek.
        -- 2=1min
        -- 3=5min
            fibaro.call(sirene3, "setConfiguration"3110-- Door Bell Sound Duration Time 1-127
        -- 1-127 Time
            fibaro.call(sirene3, "setConfiguration"413-- Door Bell Sound Volumen 1-3
        -- 1=Low
        -- 2=Middle
        -- 3=High
            fibaro.call(sirene3, "setConfiguration"5110-- Alarm Sound Index 1-10
            fibaro.call(sirene3, "setConfiguration"619-- Door Bellsound Index 1-10
            fibaro.call(sirene3, "setConfiguration"711-- Default Siren On Mode 1-2
            fibaro.call(sirene3, "setConfiguration"811-- Alarm LED Enable 0-1
            fibaro.call(sirene3, "setConfiguration"911-- Boor Bell LED Enable 0-1
            sirenen_alarm_ton = 2 --Initialisiert, der Ton kann abgespielt werden.
            fibaro.sleep(3000-- Wartezeit nach Initialisierung sonst kommt der Ton nicht richtig raus
            fibaro.call(sirene3,"turnOn")
            fibaro.sleep(3000)
            fibaro.call(sirene3,"turnOff")
        else
            fibaro.sleep(3000)
    I only initialize the siren if another sound has been played beforehand, otherwise it is only switched on and off.
    Global variable (siren_alarm_ton) is responsible for this.
    After the initialization you have to take a break or the sound will not be played back.
    Greetings from the neighboring country
    Frank
