Randaz 0
Hello all,
I have searched the forum without any luck. I am adding a light fixture on the wall by pulling power from a live outlet directly below it. I want to use the Dimmer 2 inside the box as the switch/dimmer without any type of wall switch. The only control will be thru my Homeseer setup. Can someone sketch or explain the exact wiring required in layman's terms and not just by referring to the schematics in the manual. I have been easily able to do the with an Aeotec product but now have these dimmer 2's. Thank you in advance for the help.
