NeoCoolcam Switch CH3 Switch
I have a issue when I press any button switch just 91.0 is modified and I can't verify which lights is on.
Thanks!
4 answers to this question
If I undersand correctly now it looks like device reports states only to "root" device - it should report state to specific channels.
Setting correct associations should do the trick - according to device manual.
    What i need to do?
    You need to read this:
    Then you have to figure out which channels you want to associate. It depends a little of the device. I do not know NeoCoolCam but it should follow the z-wave standard.
    If you do not want to learn about associations you could buy Fibaro switches. They will be configured correctly  during  the setup.
    Edited by Thomasn
    Associations, group 1, check this box.
