This is a" Quick and dirty" script to disable battery notifications. I use my own  notification script based on @Sankotronic's battery reporting scene (see below) HC3 uses a new API and concept to configure different notifications.
The script reads all notifications, and disables LowBattery notification without modifying any other setting. I think it is not necessary to actually call this on each slave device, but it is slightly more difficult do that once per master device.
This is only a quick demonstration of this new API (and my understanding of how to use it :D)
If you only want to enumerate the notifications, comment out line "_,responseCode=api.put("/dev........"
Notification Scene:
Edited by petergebruers
I also used the script based on @Sankotronic's battery reporting scene on my HC2. I miss it on my HC3.
Can you share the modified script?
    Good question. I'll check with the author of the script (Zoran).
    @petergebruers ,
    you have my full support to publish script and thank you for your help and work! ?
    Okidoki!
    So here is @Sankotronic's Battery Check Scene, modified to run on HC3
    • Thanks 3
    • 2 months later...
    Great Thank You!
    • 5 months later...
    Thank you. Great Scene ?
    • 4 weeks later...
    Guest iq9003
    Thanks for sharing.
    I did have an issue with the Battery Check Scene, because of my Netatmo Plugin. When running the script I got an error ("attempt to compare number with nil)".
    For now I fixed it by excluding the plugin:
    to
    Edited by iq9003
    • 3 months later...
    On 4/24/2020 at 2:12 PM, petergebruers said:
    Okidoki!
    Sorry if the question sounds too basic. How can I integrate this LUA code into my HC3?
    I have tried adding it as a QA but it is not the proper format. I have also tried to "import" the scene but can't find how. I may have to create a scene and complete the trigger part, for example run the scene every hour, and paste this LUA code in the actions section?
    Thanks a lot!
    Thanks a lot!
    Yes, you do. Every hour is a bit too much, but once a week would be fine.
    Ah, that is actually a good question. Indeed, it is not a Quickapp but "scene code". So in the browser go to "11. Scenes" and add a new Lua scene.
    In the left part, you past something like this to determine when the scene should run
    Thats every day at 14:08
    Then open the ".lua" file I posted in a text editor, and select all text, then copy/paste in the right part of the scene.
    Thank you so much! I already have it integrated :)
    After the introduction of ZigBee on the HC3, the "BATTERY CHECK SCENE" developed by @Sankotronic required some additional changes to handle ZigBee battery devices. Here is an updated version.
    • 8 months later...
    Guest macjoker
    I have made some changes so that my QuickApp devices that have battery interface were also checked.
    Now the scene supports Z-Wave, ZigBee, and QA devices.
    I did some fixes too: color messages in console and custom email subject restored. Have fun!
    @macjokerThis BatCheck scene is very usefull. Thank you! :D
