FGWP102 energie consumption chart
NielsK
Dear all,
I'm using two FGWP102 wall plugs.
Wall plug and Home Centre light all have latest frimware.
One is switching a 10.5W led light. Clean switches every day though a scene.
A little pike in the beginning of each switch-on, what might be something like heating up the led light?
I,m ok for this one.
/monthly_2020_04/image.png.12b808240e911e815abfaea09ca05ce9.png" />
The other wall plug is acting a bit different, what I can't figure out.
This one is switching a electronic dimmer with 2x28W light bulbs behind it.
When switching it on manually the power consumption is 70W.
This wall plug is set with a scene. 7 days a week: ON 1h after sunset, OFF at 2345h
2 strange things do happen:
1st) The lamp allways switches ON correctly on time. But occasionally on the moment is switches OFF, it directly within a second it switches ON again.
No other divices are set to act at that particular moment.
What can be going on?
2nd) Trying to understand the 1st issue I looked into the energy consumption chart, daily, weekly, monthly.
These graphs show something strange.
The Daily graph is showing different in the top-graph vs bottom-graph-timeline.
The Weekly graph is showing 60W (electronic dimmer was set a little lower) on the moment it switches on. That's as expected.
But at between 2330h and 2359h it shows a power drop from 60W to 45W.
And accoringly between 1430h and 1459h is shows a power drop from 45W to 0W
Looking to the montly graph every 7 days there is a drop...
Does anyone recognize above and can help me solving mainly the unexpected switch OFF/ON (as mentioned at 1st issue)
Might the electronic dimmer be the issue... (I'll do test with other lamp withour dimmer anyway soonest)
Thanks a lot.
Best regards,
Niels
