You need to set this:
self.userid = "######@###.com" -- Username
self.password = "###########" -- Password
self.keycode = "####" -- Keycode
Make a global variable called: Alarm
line: 221  fibaro.setGlobalVariable("Alarm", state)
I call my quick app (device) from a loop scene every 1 min. to get state
fibaro.call(deviceid,"uibutton1OnReleased")
DO NOT call more than every 30 sec. or I think you will be bloked by Verisure
DECLARATIONS (Conditions/Triggers)
    type = "date",
    property = "cron",
    operator = "matchInterval",
    value = {
        date = { "*""*""*""*""*""*" },
        interval = 60
    isTrigger = true
ACTIONS
You can get devices variable from a scene by
api.get("/devices/DeviceID").properties.quickAppVariables[1].value
api.get("/devices/DeviceID").properties.quickAppVariables[2].value
api.get("/devices/DeviceID").properties.quickAppVariables[3].value
etc...
line: 3   local debugging = false (show all) in debug window
line: 4   local debuggingtrace = true (show alarm state/users/devices) in debug window
I dont know yet how to show icon "red" Armed-away
Edited by Sagittarius
yes
Guest Freddan67
Which modules does it support? I'm definitely interested
    you mean what output you get? I guees all...
    I try to make a file without all my password and stuff
    Moved upload to post 1
    • 6 months later...
    Installed it great work
    Send a PM for icon change on state
    • 2 months later...
    Hi there. I'm a user in Norway with Home Center 3. I downloaded the file and uploaded it to my HC3. Replaced username, pwd and keycode. When I run it it doesn't arm/disarm the alarm. Does it still work in feb 2021(or have there been som new updates in software that make this error?).
    I haven't found out how or if I need to make a global variable(perhaps this is why I get the error?) - or is there other adjustments I need to know about. I have only done what I have described in this post.
    Hope @Sagittarius or some of you other guys can pass some help on this issue and can confirm it still works. It would have been great to make a scene where lights are switched off and alarm armed when you go to bed, etc.
    Edited by Kgudmund
    • 3 months later...
    Hi there, thanks for putting the effort in! With your example it works to turn on the lights scene when the alarm is breached. I was wondering what LUA script command to use to call the Verisure device to enable the alarm?
    Edited by MartinvdB
    • 1 month later...
      - I've been trying to set this up.
    Something is not working correctly.. after verisure forced MFA the QA won't work out of the box.
    I followed this HA guide to create a service account and remove MFA for that user:
    But all I get (still) is Post Break error.
    I can't get more debug info so I have no idea where to look for the solution.
    could you possibly assist?
    I set up the global variable.. put in a dummy value and ran the QA.. it clears the variable so there is no data in the QA get state.
    @Sagittarius - So.. I got a bit further..
    I changed the links from 01 to 02:
    Just a question.. can the qa not get status of lock.. is the door locked? is it unlocked?
    Where do you find the info returned from the api call?
    • 4 months later...
    @Sagittarius - Do you still work on this QA ?
    Just wondering if it's possible to include the state of the lock. ie. Is door locked - yes/no .
    I see verisure changed the dns name again from 02 to 01 (at least for me it's now 01)
    Oh and I can now check the lock status.
    One thing I think we need (unless the dns thing only happens to me) is to test the dns before starting anything else.
