HC-2 checksum error
jasonC
so i havn't updated my hc-2 for a while, still running 4.180. finally want to do and making preperations, tried to do a local backup and system would not do backup noticed this. what to do.
@jasonC Your problem can be traced to the Recovery Stick, the small USB flash drive that sits inside the cover on the left side. There was so much trouble with this USB memory, so Fibaro decided to no longer use that memory stick. So as of version 4.5XX, it is no longer used for backups, but these are now stored "in the cloud" or locally on your computer (you choose this).
You have no benefit of a backup from version 4.180 as it can no longer be used in version 4.5XX, which has a completely new backup system.
So I advise you to upgrade to the latest version (now 4,580) as soon as you can (and then remove the USB-stick).
Edited by RH_Dreambox
