Sending CURL commands from a LUA coded scene
Hi experts,
Sorry to bother you with this newbie question. Well, at least I think it is ;-) I am trying to get some data from my Fibaro devices and pushing that data to an InFluxDB by running a scene on my HC2.
Can someone tell me how to code the following CURL statement in a LUA scene:
curl -i -XPOST 'http://localhost:8086/write?db=hc2' --data-binary 'cpu_load_short,host=server02,region=us-west value=0.64 1434055562000000000'
I tried a POST through HTTP, but that doesn't work (most likely because of the InFluxDB version), but when using above CURL command from a Terminal session it perfectly works, but now I need to know how to do this in LUA.
Many thanks in advance, Sjaak
This is example of scene called from another scene  or VD for GET, POST data to/from others system from HC2. Is no problem implement the code direct in yours scene (this is function) or call as external.
IFor use returned data is needed to add code for use it in this scene itself or put in global variable or write ex. to source scene debug message and after it retrieve, any method is good
If you need it function http:call(method, url, user, pwd , content, datas) return all necessary data add data, status_id, err_id =  http:call(method, url, user, pwd , content, datas) in place of http:call(method, url, user, pwd , content, datas) at end of code.
data - returned_data(many time s json object/table)
status_id - status of call from server (if success return 200)
err_id - error number from called server (ex 401 - no authorised)
Edited by drboss
