Guest torneset
I have several scenes on Home Center 3 triggered by motion sensors along with condition of profile=home or profile =night, but sometimes the scenes is not triggered. In the log I can see the motion sensor register the motion but still the scene is not triggered. After some minutes it works normal again. Also after reboot the profile needs to be changed in order for these scenes to be triggered, so it seems like it can't read the profile status until it manually has been changed.
Any of you having the same problem?
Is there any way to debug or get some more logs of why the scenes is not triggered?
I tried to make a lua script to read out the set profile, but I could not find the command. Any suggestions?
Thank you
