Darryl 1
I'm currently using a couple of RGBW controller 2's with parameter 20 set as 0-10v analog inputs (on a VeraPlus).
They are used with ultrasonic sensors and when polled display accurate readings.
They just don't update very quickly when the levels change.
I have set the following to try to improve this but it has made no difference:
Parameter 63 - 2 byte dec - 1 (should set increment measured at 0.1v or 1%, the default was 0.5v)
Parameter 64 - 2 byte dec - 1800 (should set periodic reports to 30 minutes).
I changed the level measured by the sensor from 95% to 0% at around 5pm yesterday. The change was finally reported back at 03:24 this morning, over ten hours later.
Both my rgbw controllers act like this despite the parameter setting. If I poll them, the level is immediately updated and correct.
Am I missing something, or can anyone give suggestions on getting timely updates from these please?
Many thanks!
