Trikkitt 0
I'm using the FGSD-002 smoke detector, it is visible on the Z-Wave network. I wanted it to use the native Z-Wave functionality to make the lights in the house flash when smoke is detected. This is my first use of this type of feature, so maybe I'm missing something. I'm using Fibaro Z-Wave modules only for this, but my Z-Wave controller is Home Assistant, although that should make little difference given this is native Z-Wave stuff. I've configured the following:
On the smoke detector
* In group 4 (Fire Alarm Reports) I've associated 4 different light modules, two dimmers two switches.
* Option 2 - Exceeding temperature threshold notifications enabled
* Option 13 - Smoke Alarm Broadcast Active / Tamper Inactive
On the target devices:
* Option 42 - Smoke Alarm Reaction - Flashing
I can see in my trace from Home Assistant that it is getting the smoke event:
2020-05-10 17:28:17.907 Info, Node026, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Smoke event:3, status=255
2020-05-10 17:28:17.907 Detail, Node026, Refreshed Value: old value=0, new value=0, type=byte
2020-05-10 17:28:17.907 Detail, Node026, Changes to this value are not verified
2020-05-10 17:28:17.907 Detail, Node026, Refreshed Value: old value=0, new value=3, type=byte
2020-05-10 17:28:17.908 Detail, Node026, Notification: ValueChanged
2020-05-10 17:28:17.936 Detail, Node026, Notification: ValueChanged
2020-05-10 17:28:17.951 Detail, Node026, Notification: ValueChanged
2020-05-10 17:28:17.965 Detail, Node026, Notification: ValueChanged
So I know a report is being generated by the smoke alarm, but I can't see any reaction from my other devices. This was a fundamental reason for buying the Fibaro smoke detectors, so any help in getting this working would be much appreciated. I really want to avoid any reliance on the controller.
Mike
