Fabian78 0
I've got a led light LED G9 2W together with a Fibaro Dimmer 2 and the Fibaro Bypass.
I don't have the blue (N) wire near the wall switch, so I did the solution as Fibaro also suggest with a two wire connection (connect the SX with the N of the dimmer).
I have installed the bypass before and after the Led bulb in het ceiling.
But this isn't working:
When I turn on the power, the Dimmer is starting the callibration proces.
The LED light in the dimmer is green.
But after the calibration, the light is on, but the wall switch isn't working, and the Fibaro system says it lost connection to the dimmer.
Nothing is working and I can't turn the light off with the wall switch nor in the Fibaro systeem.
I've tried everything.
When I change the LED light with an old, normal light, everything is working fine, the wall switch works and the Fibaro system finds the dimmer again and I can switch it in the system.
What I am doing wrong?
I think the LED has to less power, but I thought I could solve this problem with the bypass.
It isn't possible to use the blue (N) cable, because the cables in the wall are stuck. I've tried to pull an extra cable from the ceiling light unit to the wall switch, but I didn't made it.
6 answers to this question
