Problem with the netatmo thermostat panel
I installed a Netatmo thermostat, which works very well.
I installed the Netatmo plugin with all the right configurations to connect my Netatmo account.
I have in the plugin the confirmation that my account is connected.
After a few minutes the panel of my thermostat appears in the devices in my fibaro interface, but when I press the buttons to control it (for example change the temperature or put it in "away" mode), nothing happens.
And another question, I couldn't find any possible action to make the thermostat interact in scenes, is this normal?
Thank you for your answers
I have the same problem. Looks like "account is connected" but I may only see only control panel and act nothing. Numbers appearing on control pannel are not correct.
