Lack of devices' status synchronisation between two connected HC2
I have two HC2 connected together (Master and Slave).
Devices are properly imported from Slave to Master but when logged on to Master I don't see the proper status of the devices. Eg. Master shows the light is ON when it is OFF.
The same incorrect status is seen by the Fibaro Apps connected to Master.
Any way to fix it and have the device statuses permanently synchronised between the two Centrals?
Thank you in advance,
I have the same problem between an HC2 and a Lite. You already solved the problem xfire?
