Security alert Fibaro System Suspicious Login Attempts
Hi There,
I received an annoying message everytime for Fibaro Suspicious login attempt and there is not even someone home.
I have no google account linked to Fibaro and have HC lite with software version 4.560.
Can someone help me to get rid of this annoying message.
Thank you
7 hours ago, jbos04 said:
Hi There,
Thank you
Hi
I had the same problem, the trick for me was to close port 80 on my router. Port 80 was "forwarding" (all) traffic to my Fibaro HC2. (btw I was not aware that this was not needed to connect from outside the WiFi network (= internet)
Hope this will solve the problem
    Hi Patrick,
    Thank you for your reply and will give this a try.
    • 2 months later...
    I do have the same issue:
    • Everything worked fine
    • I got a recommed password change from fibaro
    • So i did.
    • My app ofcourse asked for the new password
    • Now I get since yesterday evening:
    • Suspicious Login Attempts Prevented
      We noticed 5 failed login attempts to your HC2-027929 that seemed suspicious.
    • after trying every half an hour
    • it doesn't work at two iphones (from the home IP adress)
    • password is correct (the same I use to logon online via home.fibaro.com)
    • I have had port 80 opened, but closed now (according the tip above)
    Anyone any suggestions?
    I also get that message when I remotely connect to my Home Center from my current worksite over the satellite connection and through Norwegian ground station.
    It is a bit slow connection, but I manage to login to Fibaro ID and then to my HC2, check what I have. After logging out I always get this message wondering why?
    solved the issue by deleting the HC in the app and clicking on 'new' HC (it remembered my HC settings). I had to reconfigure my widgets though...
    • 1 year later...
    In my case the warning message states "We noticed 5 failed login attempts to your HC2-qrxyzw that seemed suspicious.
    For your security, the following IP address: 127.0.0.1 has been locked for 30 minutes."
    However this IP-adress normally doesn't represent an adressable device.
    On the LAN to which my HC2 is attached all clients do have IP-addresses do have adresses 192.168.3.xyz.
    In order to track down which client is causing this I need the IP-address of the LAN-client alternatively it's MAC-address.
    Cheers
    • 3 years later...
    Any news regarding this? I have the same message
    Hi @emariu ,
    What news do you expect? Usually you get IP address from which login attempts were made, so you can check if any of your devices are doing this.
    Hi @sorken48 ,
    The IP address 127.0.0.1 is called the loopback address and is used by a computer to refer to itself. It is also known as localhost.
    So, check if there is any code that uses this e.g. inside VD:
    or even better inside some scene:
    where basic authorization is used and probably you forget to update username or password.
    BTW - its been long time since I last have seen this notification for both HC2 and HC3.
