Guys and Girls,
I want something in my HC2. It's no rocket sience but I can seem to make it work. Any clous?
Case:
 I have a Fan for toilet and Bathroom (humidity and smell). One fan for both.
There is a Humidity sensor in the Bathroom which I want to use to start the fan above value "X" and stop when the humidity is below value "X". BUT... When someone has used the downstairs toilet and the have pressed a button for the fan I want the fan to start for lets say 5 minuits.
To prevent that the bathroom Humidity or the 5 minuts timer shut the fan down when one of the values isn't matched I want to make something like this:
Bathroom, above value X = on
Toilet when pressed button (in app) = on and off after 5 minuits
Bathroom below value X AND timer of toilet has not been completed = OFF
Toilet timer is completed AND bathroom value is below X = OFF
I have been playing with Variables which seems the most logical option but there is no possiblity for a 300sec timer....
Fibaro can't be this dump to have not such possiblity so can you help me where I'm going wrong.
Bert.
did you read that?
Quote
HC2 version 4 has a new primitive for timing: setTimeout() with arguments "function" and "time in ms".
I's available in scenes, but it's not in Virtual Devices. Here's an example, starting from a script based on sleep:
ID=207
fibaro:sleep(1000)
fibaro:call(ID, "turnOn")
fibaro:sleep(2000)
fibaro:call(ID, "turnOff")
The semantics of "setTimeout" are different. It means "Schedule this function to run after this time interval has elapsed".
So the first argument is a function. Defining a function is easy: wrap the actual command you want to run in "function() .. end".
In the next script I've put the on/off code in functions, and scheduled them... but there are two pitfalls.
One: don't use () after the first argument (that would make it a "function call" instead of a function).
Two: because the timers in this script start at the same time, the second timer has to be 1000 + 2000 = 3000 to be equivalent to the first example.
ID=207
function lightOn()
function lightOff()
setTimeout(lightOn, 1000)
setTimeout(lightOff, 3000)
There's something important here and it's easy to miss. You see in setTimeout we refer to "lightOn". You
think that is a function call? Sure? It isn't: it's a variable bound to a function, not a function *call*.
A function *call* would be like this: "lightOn()". If you put the "()" like you are used to do... the script won't work.
When the script arrives at the setTimeout call, it immediately executes the function call. So add "()" to lightOn and the light will switch on immediately, instead of after a 1 second delay.
And after one second, you get a mysterious "LUA error: attempt to call a nil value". That's setTimeout barking at you: "Hey, where's the function you want me to call after time out?".
Please note that if you can't use "()" then you also can't have parameters. So "lightOn(ID)" isn't going to work either. I'll write about that later.
Maybe you don't like the idea of the two functions being scheduled at the same time, maybe you want to see the second timer at "2000" in your script.
Then you can refactor it like this. The first timer is OK. But the second timer should start in the function of the first timer, so they are "chained".
When I do this, I change the name of the first function from lightOn to lightOnOff because that is what it will do.
Then at the end of it, I put the second setTimeout, that was at the bottom, and change the time to 2000. Like this:
ID=207
function lightOnOff()
  setTimeout(lightOff, 2000)
function lightOff()
setTimeout(lightOnOff, 1000)
Lua supports anonymous functions, and that can make a good solution for simple things...
But I think this often gets hard to read. I put this example in anonymous form. And I payed attention to the indentation.
But you still have to go through the text a few times to decode the pieces. On the other hand, it's valid and concise.
setTimeout(
  function()
    setTimeout(
      function()
But don't give up on this anonymous-function-thing. You'll need it if you want to use parameters with setTimeout.
Remember I said you cant put parenthesis after the function name in setTimeout?
I'll offer two solutions to work around this. First, you can wrap the function in "function()"
<CODE HERE> "end". That defines an anonymous function, which contains the statements and the parameters you want:
my_ID=207
function lightOnOff(id)
  fibaro:call(id, "turnOn")
  setTimeout(function() lightOff(my_ID) end, 2000)
function lightOff(id)
  fibaro:call(id, "turnOff")
setTimeout(function() lightOnOff(my_ID) end, 1000)
The second solution is the real "functional programming" stuff.
Can you design a function, that *makes* a function for you that does the right thing and can be called from setTimeout?
That's what's happening here. Functions are "first class citizens" and can be passed around and can be used as variables.
This is the same example, but this time the argument for setTimeout is created inside a function, makeLightOnOff(id).
This works because, well, if you're not used to functional programming, this might blow your head off, functions in lua are "closures".
That means, they capture the local variables from the context *outside* the function (I'm talking about "id").
my_ID = 207
function makeLightOnOff(id)
  return function()
    setTimeout(
      function()
      end,
      2000)
my_on_off=makeLightOnOff(my_ID)
setTimeout(my_on_off, 1000)
The "Lua idiom" to setup a non-drift setTimeout loop is
Ex. a 60s loop
local time = os.time()
local  function loop()
     doWork() --- call function or do whatever needs to be done each loop
     time = time + 60 -- calculate next time we should be called
     setTimeout(loop,1000*(time-os.time())) -- subtract current time from wanted time
loop()
In this case, if 'doWork()' takes a millisecond or 30s it doesn't matter. The loop will run every 60s.
However, when in the minute doWork is called depends on when the loop is started. If it is started 10:05:26 it will loop
10:05:26, 10:06:26, 10:07:26, 10:08:26 ...
This is easy to extend to make it run starting on the minute (works for hour too)
E.g. looping 10:06:00, 10:07:00, 10:08:00, 10:09:00 ...
  local interval = 60
    doWork()
    time = time + interval
  time = math.floor(time/interval)*interval+interval
and then the pattern can be captured in a function
function loop(fun,interval,startOnInterval)
  local function doLoop()
    fun()
    setTimeout(doLoop,1000*(time-os.time()))
  if startOnInterval then
  else
    doLoop()
loop(doWork,60,true) -- run doWork() every 60s starting on the next minute.
