DonCW 0
I have moved to the HC3 and trying to work out how the LUA programming works.
The HC2 programming seemed a lot more logical and I am struggling to work out how to convert some of my old routines over.
One of the first routines is remotes. Setting this up by blocks wouldn't work as it looks like I'd have to setup a scene for each button for each remote.
Could someone help tell me how to convert this simple program into a HC3 computable version?
%% properties
13 sceneActivation
%% globals
local buttonPressed = fibaro:getValue(13, "sceneActivation")
if ( tonumber(buttonPressed) == 1) then
fibaro:debug("MiniMote button 1 pressed")
elseif ( tonumber(buttonPressed) == 2) then
fibaro:debug("MiniMote button 2 pressed")
elseif ( tonumber(buttonPressed) == 3) then
fibaro:call(4, "turnOn")
fibaro:debug("MiniMote button 3 pressed - Light ON")
elseif ( tonumber(buttonPressed) == 4) then
fibaro:call(4, "turnOff")
fibaro:debug("MiniMote button 4 pressed - Light OFF")
elseif ( tonumber(buttonPressed) == 5) then
fibaro:debug("MiniMote button 5 pressed")
elseif ( tonumber(buttonPressed) == 6) then
fibaro:debug("MiniMote button 6 pressed")
elseif ( tonumber(buttonPressed) == 7) then
fibaro:debug("MiniMote button 7 pressed")
elseif ( tonumber(buttonPressed) == ? then
fibaro:debug("MiniMote button 8 pressed")
else
fibaro:debug("No response")
