ive got a question to HC2 and Triggers...
I would like to set up a scene like this: if the motion detector trips between 5 a.m. and 6 a.m., the shutters should open. Is that possible in the HC2?
I cant find this trigger. In HC3 is this time trigger... can help me someone or do I have to buy the HC3 because of that???
Thanks for answers
Tschorden
I use this code:
-- Set formato data
local Adesso       = os.date("%H:%M")
local InizioSilenzio     = "07:00"
local FineSilenzio         = "09:00"
-- Sezione Emissione suono attivazione
    if
      (Adesso  > InizioSilenzio and Adesso < FineSilenzio)
    then
       logbug("GREEN","Non emetto il suono")
    else
      -- soundSiren(53, 1, 500, 500)
       logbug("Green","Emesso Suono")
I mean:
between 07 and 09 the siren must not sound, otherwise the siren will sound 1 second.
See if you can adapt it,
Edited by MarcoTorino71
ita-eng
