Adding second flood sensor
TGrantT
I have two Fibaro flood sensors, which I want to pair with a Smart Things hub. The first will pair fine, but the second is not found. I have seen a suggestion that I need to use the Identify function for two identical devices, but can find no information on it. I did rename the first sensor after pairing.
