I want to create a few extra scenes with a good weather provider. A lot of providers do not work anymore. which one can I use?
Erik
7 answers to this question
1 hour ago, erikbosman said:
I want to create
do it!
/monthly_2020_05/image.png.c171477b6c7b4ea6d4d47895865f48da.png" />
    I do not have that option in Fibaro Plugins. See attached print screen.
    To avoid misunderstandings, you should specify which controller you have. @ 10der gave you an answer for HC3, but your question was intended for HC2.
    YrWeather works just as well, but if you want to choose a Weather Provider yourself, OpenWeather works pretty well.
    Edited by RH_Dreambox
    I have a HCL.
    For The Netherlands de Buienradar can also add some extra and nice features.
    Buienradar is not working on HCL. Is there another weather plugin i can use?
    Guest ChristS
    I'm using the Yr weather provider on my HCL and it works very well. It reliably reports current weather condition and wind speed, so I can recommend it. The only thing I am missing from it is that it only has one level of cloudy. I would have loved if it was able to distinguish between partly cloudy (mostly sunny) and completely cloudy (danger of rain).
