New bathroom, which modules?
I'm getting a new bathroom in Juli and want to use some Fibaro here, I don't know which module I can use best.
I want to control the bathroom fan and new LED lights in the ceiling. I don't need to dim the LED lights.
Do I need the Fibaro Single or Double Switch or do I need the Relay version? When I use one of these in combination with my LED lights they will not flicker?
Thank you in advance ?
4 answers to this question
I use the Everspring ST814 to measure the humidity level and a relais switch to control the fan. The Everspring connects via an association with the relais switch based on a humidity level (for me 65% on and 58% off).
My idea should be IKEA Tradfi lights cheap and dimable (in the night 50% others it will blind)
Door/ window  sensor
Motion sensor
For emergency or manual a walli switch or even better a HUE or IKEA switch
Since short my bath room runs without any switch.
For an excellent operation you need also a motion sensor outside to detect if already someone is inside the bath room if person 2 enters also.
Remark:
Motion sensor AEONLABS with USB 230 Volt needs wall connector.
AEONLAbs measure humidity and switch on/off central fan difference in humidity and ambiance!
Central fan 3 speed >>>1 fibaro Dubble relay
speed 1 24/7
speed 2 when bath room toilet is in use
speed 3 use bath room or toilet > 3 min
speed 3 in case of humidity
//Sjakie
Flicker will not be a great concern. But beware of the inrush current. This can destroy you're smartswitches.
    Thank you guys for all your answers.
