Hello forum.
I want to get one thing straight. What does a HCL in slavemode do if paired with HC3 master?
Can I place the HCL near devices far away from HC3, using a wired LAN cable - connect the far away devices to HCL and synchronize with HC3, to make the devices connected to the slave, appear ind the HC3 interface?
Best regards,
Troels
  • 3 weeks later...
Hello Troels, If i understand correctly, the HCL Slave of HC3 should work similar a HCL being salve of HC2.
I Jus got experience configuring HCL as Slave of HC2. If anyone find something interesting about HC3 slave mode please share below.
Regards.
We do not know 100% for sure yet, that feature has been delayed... ETA 2021:
    Thanks for update. Fortunately I do not need the Slave function, since the improved range of the HC 3 does the trick for me.
    Edited by Troels
