Cannot set Dimmer 2 to pairing state
Hi All,
After rearranging some modules in my home I am not able to pair a Dimmer 2 module again. The new set up is  2-wire set up. I followed the instructions for reseting the module through B-button (even tried with Reconfiguration from my HC2 before removing it from the controller). When I press and hold the B-button there is now indication for reseting or entering the menu. Only stay green lough is on.
I removed it from HC2 without following the instruction for "Removing (Exclusion)" from the Z-wave network, but as I said I was not able to bring the pairing state by holding B-button.
I tried pressing B-button 3 times or switching no/off 3 times S1 when HC2 is in adding mode to pair it again, but no success.
No meter what I do the lights are aways on (14x5W led lights GU10), green led light is on, not letting me to reset ot pair again.
First try to exclude the device again (it doesnt have to be known to the HC2, you can exclude it anyway)
And to include try very fast pressing more than three times (like 5 or 10 times) That helped me.
