kevin 34
I’m trying to write a LUA scene where power value is the trigger. I want that if power is above 8 then press button 2 on VD once. If power is below 7 press button 4 once.
Now when I write a scene like this, everytime there is a power change above 8 watt the button on the VD is pressed. That trips my HC2 and VD.
How can I solve it that the VD button is pressed once when the power is above 8 watt regarding the power value changed above the 8 watt?
21 answers to this question
