Hi All,
when I look at the openweathermap QA example, they defined their own properties like wind etc. As I would like to grab the rain as well, I would like to add a custom property to the QA in order to be able to access this information from another scene or QA.
How do you define customer properties in a QA? I was now search of a long time without success :-(
When I just do a self:updateProperty("rain", 0) nothing happens
Thank you
Roger
@A.Socha@jgab
4 hours ago, rhalbheer said:
Hi All,
Thank you
Roger
ugly but works:
local users = {
    Oleg   = {mac = "", presence = false, lastSeen = 0},
    Helena = {mac = "", presence = false, lastSeen = 0},
    Katrin = {mac = "", presence = false, lastSeen = 0},
    Sofiya = {mac = "", presence = false, lastSeen = 0},
[skipped]
self:updateProperty("userDescription", json.encode(users))
2 hours ago, 10der said:
@A.Socha@jgab
ugly but works:
local users = {
[skipped]
It seems like the device definitions for the different device types are defined by xml schemas that only accept specific fields. Therefore we can’t add any property to devices, although different devices have different fields.
    Hmm, interesting. But the openweathermap QA has properties like temperature, humidity etc. So, there has to be a way. I might need to look at the exported QA then. But this would be quite a hack. This QA actually brought me to the idea. I uncommented the rain part of the QA and added it to a label. It would be nice to have it in the properties as well as this would be really easy to access from other QAs and get the value transported without exposing it in the variables.
    If you create a QA with the same device type you will get the same properties.
    Yes, the argument for custom property fields is that fibaro.getValue would work.
    @jgab: True but somehow the person who did the openweathermap QA defined custom properties and I do not get how. It is not part of the fqa file but it is there if you go to /api/devices/<id>. I would have expected that the self:updateProperty would work the same way as self:setVariable to define a new one but this does not seem to work.
    So, again, somehow it has to be possible because openweathermap seems to have done it or not?
    But if you create a QA of type com.fibaro.weather you get temperature, humidity, wind,weathercondition, conditioncode properties.
    But you can't add rain (unless as a part of weathercondition).
    These are the same properties as openweathermap has.
    No custom properties, just the properties supported by the com.fibaro.weather device type.
    Hi guys,
    In HC2  I had a scene and VD  OWM. I  have used clear sky, over clouds and clouds>>> it will trigger to close curtain by sunshine between time frame (sunrise+01:00..sunrise+01:30)
    How to accomplisch in HC3?
    thanks in advance,
    //Sjakie
