IK have made an alarm. After that mij HCL does not work. I made a recovery and I can log in but I can't do anything. I can't put no new devices to my HCL, I can't make any scenes and I can't restore a backup. What can I do? My HCL does not working.
Edited by JoeriKok
i made a fault in the language
  • 1 year later...
I have this same issue. I can see the list of backups, both cloud and local - but the option to take new backups, or to restore is missing.
My HC2 died yesterday, and when I selected recover, it came up with empty config and no possibility to install from backup.
I have a customer with the same issue.
  • 2 months later...
Hi @
, have you solved the issue? I have exactly the same,
Did you shutdown the HC2 or waited it out ? And what was the consequence if you restarted the HC2?
  • 2 years later...
Hi everyone.
I also have this issue and unfortunately I see no solution for it in this forum.
Has anyone been able to solve it or must I scrap my HC2 and all the system configurations in it?
Hope somone can help.
Thank you.
Kind regards.
Edited by Faustino Moreira
  • 3 weeks later...
The solution:
If you factory-reset your HC2 (for example as a part of transferring the configuration of a dead HC2 to a new one), then you must login as admin/admin on the next boot. Those are default credentials for Administrator.
Otherwise, you will have USER permissions only, which are not enough for restoring the old backups nor for adding new devices etc.
PS: How to transfer configuration and backups from a dead HC to a new one:
