Heat Controller FGT-001 firmware update 4.7 description missing
marbe
Hello, there is new FW 4.7 for Heat controller, but for new functions I need description and I cannot find it at modules update or manuals.
Here is Changelog of FW 4.7 for Heat Controller from HC3.
4.7:
  • Function for reporting the demand for the heating medium enabling optimal control of the furnace,
  • Heating system diagnosis function. Informing about problems with reaching the set temperature,
  • Improved operation of the window opening detection function,
  • Added the parameter for changing the direction of the thermostat knob.
Warning:
  • Update can take up to 30 minutes. It depends on Z-wave traffic,
  • If possible, locate the device in the close nearby (ca. 2m) of the Home Center to avoid failures,
  • Wait few minutes after successful update and check if version of device has changed,
  • The update use the Z-Wave network bandwidth to a large extend. It may result in delays in other network actions even several minutes after update.
  • In case of strange device behaviour there may be need of reconfiguration/reinclusion.
  • Thanks for answer. I need description of parameters as well.
    And there is new parameter moderate function too, please, describe it.
