xTr 2
So I've setup the intercom using the app.
I'm unable to configure anything at all - like no settings panel or anything ( android ) the ring functionallity works along with talking/video/opening in both ways, but that's it, cant add new users or modify settings.
The MJPEG stream works fine via http and local ip, the API seems to work fine as well.
However when I try to use the web app
I get response:
This is not a valid IP address of the FIBARO Intercom.
And yes, the ip is valid local address ( 192.168.3.XXX ) and the device I'm accessing from is on same subnet.
So I can't access settings in android app? And can't access webpage either. I did factory reset once already.
