I'm trying to get the status of my alarm system through the two inputs of a Universal sensor.
I want three things to happen:
 - alarm activated (no one home) - switch all lights off
 - alarm deactivated - switch selective lights on
 - alarm trigger - all lights on
I've programmed the two outputs on the alarm panel to drop to ground when the status changes, this works
the relays switch depending on the status of the alarm panel
But I'm still doing something wrong because Fibaro doesn't switch any lights when the status of the alarm changes
 - am i using the correct parameters in the scene
 - do i need to change something in the setting of the universal sensor
   (i've already changed parameter 3 and 4 to "0" (normal open input)
Maybe there's someone here that can tell me what I'm doing wrong
(added a few images)
Gary
