TSN2 5
I hope somebody can help me here. i had a scene that worked perfect but after update to 4.590 it went nuts. Screens where going up and down 20 times in 1 minute.
now i changed the scene and tryed to made it as simple as possible. But i cant get it to work. it keeps making the counter 0. While it shoud not do that (i think).
Its this scene:
%% properties
189 value
%% weather
%% events
%% globals
--local sourceTrigger = fibaro:getSourceTrigg
--local startSource = fibaro:getSourceTrigger();
local Up = fibaro:getGlobalValue("Zonw_op")
local calc = Up - fibaro:getValue(189, "value")
if
((Up > fibaro:getValue(189, "value")) )
then
fibaro:setGlobal("Zonwering_terras", "0");
print (Up)
print (fibaro:getValue(189, "value"))
And i had some more triggers in it, but this one seems to go wrong every time the outdoor lux changes.
i tryed to change this line: ((Up > fibaro:getValue(189, "value")) ) TO ((fibaro:getValue(189, "value") < Up) )
but nothing works.
the value of Up is set to 800 (doesnt change at al)
the value of 189 is at this moment far above 800, but every change of 189 makes the Zonwering_terras change to 0 again ( other scene makes it go up with 1 every 2 minutes, that one works perfect)
i cant figure out what im doing wrong, even if i make this in block scenes it goes wrong.......
thanks for any help.
Greetings TSN
6 answers to this question
