im trying to set time on Global variable how do I do this on the new home centre
4 answers to this question
fibaro.setGlobalVariable("var_name", "123")
try
print("===========================================================")
print("Begin Script Demonstrating Time Stored In A Global Variable")
-- First manually create a Global Variable in the UI in Settings > General > Global Variables.
-- In this example I chose MyTimeGlobalVariable with a value of 0
-- Alternatively you can create it dynamically using API calls
-- Then run code as needed to get and set the value for the Global Variable
-- set it
hub.setGlobalVariable("MyTimeGlobalVariable", tostring(os.time()))
-- get it
local myTime = hub.getGlobalVariable("MyTimeGlobalVariable")
-- use it
print("myRetrievedTime:"..myTime)
-- improve it
print("A more readable time:"..os.date("%Y-%m-%d %X", myTime))
print("End Script Demonstrating Time Stored In A Global Variable")
