[SOLVED]can't save my luacode to VD
Good morning,
I can't save my lua code on my VD.
When I modify an existing code on vd or if I create a new module, it is impossible to save it.
When I press the save button ( on the right of ! ) on the tabs on the right, nothing happens.
But this problem occurs only if I connect through the cloud. id.cloud.fibaro.com, locally I have no problem.
Do you have an idea?
i have a HC2, version 4.590
thank you in advance
7 answers to this question
Same problem with scenes. Seems to be a problem with Fibaro servers. Locally everything works, remotely not so much. Bug has been reported by us this morning.
confirm. You can't save changes to scenes or new scenes remotely. v 4.59
Previous firmware has the same problem, so it is not firmware related, but remote server related. Let's hope it is fixed soon.
    Hello @K.Drozynski
    for me, everything seems to be in order.
    I'll come back to this forum if a similar problem / linking
    Thank you very much for the responsiveness.
    3 hours ago, K.Drozynski said:
    @bornet_sj0u, @Comfortica, @boa the problem has been fixed. Can you please confirm whether or not you are still experiencing the problem?
    Has been fixed last week, thanks !
    Now the changes are saved. thank
