Scenes will not be moved and need to be created again ?!?!?
On my HC2, currently software version 4.55 is running. Now, the possibility to update to software version 4.59 is there, but, it is written, that...
- If you have thermostats, they will await reconfiguration.
- Scenes will not be moved and need to be created again.
- Virtual devices will not be moved. Use a new tool - Quick Apps - to implement them.
Is this a bad joke ?!?!?
To say it the polite way, I am not amused...
Using the Fibaro in an business environment, and having dozens of scenes (automations), I am sorry to say, that I percieve the lack of customer orientation as an offending behaviour.
the complete text is only for HC3 transfer.
Version 4.590
The possibility of transferring the cloud backup to Home Center 3!
- Use the Transfer Configuration feature available from the Remote Access (home.fibaro.com).
- Both gateways must be assigned to the same Fibaro ID account and available on the Home Center list.
- The backup must be created on version 4.581 or higher.
- Home Center 3 must be on version 5.021 or higher.
- All Z-Wave devices, their configuration, room assignment, associations and parameters will be transferred.
- The gateway from which you are moving the backup will still be available, but the devices will no longer communicate at all.
- The migration process cannot be undone - it is irreversible.
I can confirm this just updated the HC2 to 4.590
Scenes are working / some Fibaro thermostats needs a reconfiguration (not a new inclusion).
Hello.
I have had recently updated to 4.590 Version, there is no escene  issue.
If i understand correctly this issue is only for transferring to HC3.
Regads.
