I have purchased a single switch 2 for the main living room light. I would like to install  this in the ceiling rose because my back boxes are only 25mm. I have attached a photo of my Ceiling rose wiring and switch wiring to show the current switch set up. Can anyone help with this?
unfortunately you cannot install in the ceiling rose as you are only seeing the switched live and neutral wires only.
The only way you could potentially install is by leaving switch on permanently to supply power to the module and wiring the ligt in that way. But you would only be able to control the light via automation only.
