luftdaten info fibaro
I use a particle meter from luftdaten.de to measure the amount of particles (PM2,5 and PM10) and this works quite stable.
It would be lovely if someone could write an VD to display these values and make these values usable for fibaro home system. Beside particles it can also measure temperature and humidity. (usefull also as a cheap netatmo device killer :-)
The data.json looks like this:
{"software_version": "NRZ-2020-129", "age":"19", "sensordatavalues":[{"value_type":"SDS_P1","value":"34.80"},{"value_type":"SDS_P2","value":"27.05"},{"value_type":"temperature","value":"17.20"},{"value_type":"humidity","value":"70.80"},{"value_type":"samples","value":"4974086"},{"value_type":"min_micro","value":"27"},{"value_type":"max_micro","value":"20070"},{"value_type":"signal","value":"-79"}]}
with these visual actuals:
15 seconden sinds laatste meting.
Sensor Parameter Waarde
SDS011 PM2.5 27.0 µg/m³
SDS011 PM10 34.8 µg/m³
DHT22 Temperatuur 17.2 °C
DHT22 Rel. luchtvochtigheid 70.8 %
WiFi Signaalsterkte -79 dBm
WiFi Signaalkwaliteit 42 %
Is someone able to create this VD or help me out?  We can use this VD to send out warnings when the PM10 is to high due to BBQ activities of close windows etc.
10 answers to this question
Nice initiative,
Didn’t know that one. Are also ready build sensors for sale or only DIY?
Edited by SmartHomeEddy
Some time ago we made a VD to get power consumption from the P1 Monitor. I think the logic is the same. Via the API we get the json information and we put it in labeks (and put the consuption in an unused device).
I don’t use my HC2, if now use a HC3, so I can’t build the VD.
Maybe you have some use with this example.
    Mmmmmm.. If some one please could help with this VD, I am not a noop, but not in a good programming-shape ?  For those programing everyday it should be a 4 minutes fix :-)
    10 hours ago, SmartHomeEddy said:
    Nice initiative,
    I did build it myself using this link:
    well, it looks doable (I ordered one, lets see)
    I did give it a try, for a quickapp. But from
     (10061 is an example ID from a working sensor) I get a different json structure back, a more complex json structure.
    or
    The API gives the sensor data of the last 5 minutes. In this case two rows. I don't know how to handle two data rows.
    For your json table I have a QuickApp working (without the actual collection of the data from the sensor because I don't have the sensor)
    Cool!!!
    The json data of you, did you get it directly from the sensor with an API or something?
    I have made a QuickApp to retrieve data from the SENSOR.COMMUNITY. Not to highjack your item, I placed it in a new item:
    @Barend76 where did you got this data.json from?
    (The json from sensor.community is different)
    To build a VD more info is needed.
    (I have the sensor also up and running)
      and then the IP adress of your local device :-)
    Thanks, didn”t find that anywhere
    btw it was indeed easy DIY.
