I purchased a Qubino Smart Meter (to control the readings and consumption of some of the loads in my house) and a Home Center Lite and I have a compatibility problem between both.
I'm not getting a real time reading of the values. After contacting Qubino, they say my problem is not having the S parameter (under the settings of the device / Advanced tab scroll down under the Associations / Setting associations) marked.
In fact, I had not marked it and whenever I try to do so, my amendment is not saved.
This setting is necessary for the gateway(HCL) to receive the reports from the device(SM). I've already contacted FIBARO but got no response. Anyone with the same problem who can help me?
Ty
After adding a Neocam plug i had to add parameters/registers as well. I found you must:
-1 add one register at a time
- save
- then reload the page
- then add the next register.
Or Fibaro could add the device to HC2, but i guess the little support they did is gone now.
